szafek_ml Posted May 23, 2011 Report Share Posted May 23, 2011 Hi. My task is to communicate Vision 230 PL with UniOPC(TCP Call) by GSM modem Fastrack Xtend (replacement of Wavecom Fastrack Supreme (in theory )). After succesfull initialization (SB82 is set) modem can't register to GPRS Service :/. In my case APN is "m2m.plusgsm.pl" and there is no user or password. I read at other forums that this mdem use something like WIPSOFT. I try to estabilish connection as TCP server by AT commands like: AT+WIPCFG AT+WIPBR ... and that was susccesfull but any recived data was indicated by "+WIPACCEP and +WIPDATA". In this case eneter to data mode is preblematic for me. What At commands are using by V230 to estabilish connection wit GPRS and register to network? How i can check that my modem is able to use with V230? PS. Sorry for my english. I'm still learning . Quote Link to comment Share on other sites More sharing options...
