Joe P Posted September 9, 2019 Report Share Posted September 9, 2019 I am trying to use this dll to actively work with the data tables in our plc's and our Access database. I am only concerned with the most recent entries into the table, which I am assuming will be the most recent entry or the last row of data. Is there a way to call the data table and reference only the last row of data? All examples I have seen require a row/col index which will not work as the table will change over time. Quote Link to comment Share on other sites More sharing options...
