Mickael Posted July 8, 2011 Report Share Posted July 8, 2011 Hello I ask me if it's possible to know the list of file (name) present in a folder of the SD Card Best Regards Mickael Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted July 8, 2011 External Moderators Report Share Posted July 8, 2011 There is a special function button you can place on the touchscreen that will allow you to view the current folder contents and delete files if desired. There are several parameters to set, so check the help file. Best of Luck, TM Quote Link to comment Share on other sites More sharing options...
Mickael Posted July 11, 2011 Author Report Share Posted July 11, 2011 Yes I Know but like this i have to select one by one a filename But i wish to know every filename present in one SD folder (EXCEL1) Thanks Quote Link to comment Share on other sites More sharing options...
