Damian Posted July 13, 2011 Report Share Posted July 13, 2011 We need a "No Color Change" option for the "Disable Mode Color" and "Disable Text Color" page properties. Having a global color for all disabled objects doesn't work out well aestheticly in many/most cases. Quote Link to comment Share on other sites More sharing options...
Damian Posted July 13, 2011 Author Report Share Posted July 13, 2011 We need a "No Color Change" option for the "Disable Mode Color" and "Disable Text Color" page properties. Having a global color for all disabled objects doesn't work out well aestheticly in many/most cases. Or much more preferrable, but I am sure much more work as well, to have that property selectable for each object rather than making it global. Quote Link to comment Share on other sites More sharing options...
