Rikki Posted February 10, 2021 Report Share Posted February 10, 2021 Hi I have installed UniOPC Server on Windows-10 PC. I am having an issues. UniOPC DCOM Settings "11. Click the Default Protocols tab. The default protocols should appear as shown in the figure below; if they do not, update them." Help shows two entries at this point: "Connection-oriented TCP/IP" and "Connection-oriented SPX". I have the first entry, but not the SPX protocol, so no, my default protocols do not match what the help information says they should match. Is this a concern? or How can I add a Connection-oriented SPX protocol ? I also have problems at this step from Help: Register OpcEnum: "Start> Run>OPCENUM /regserver". My 64-bit Win 10 PC says "Windows cannot find 'opcenum...'. Can you please help with the issue. Quote Link to comment Share on other sites More sharing options...
