yamid pineda Posted June 5, 2021 Report Share Posted June 5, 2021 Hello everyone I am currently working on a project for a packaging machine. The objective is to turn on a servo controlled by a driver for that reason I need three data: enable, frequency and percentage of util, in the attached image you can see the programming to generate the pulse train, however, the reference to the driver is not reaching . the module used is a UID 0808THS which has block 1 configured in PWM. What should be the correct configuration and programming to generate the pwm for an output of the module? image : https://drive.google.com/file/d/11qWhvxxzjiBgqkMM_-2XtnRRP0yG9yK9/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
