KamilK Posted June 15, 2021 Report Share Posted June 15, 2021 Hello, I have a problem with using buttons - when i click on button on HMI via VNC it is pressed even if I realese touch. Changing button setting (Attributes -> Actions -> Tringger) - trigger into Press, Release or Click/Tap does not solve the problem (on Click/Tap I cannot press again to put it to 0 state) . I am using PLC USC-x10-TR22 and for VNC - VNC Viewer and I have the newest software and firmware. Am I missing something simple or is it problem with PLC/VNC? Best regards Kamil Quote Link to comment Share on other sites More sharing options...
