Fernando Castro Posted August 17, 2021 Report Share Posted August 17, 2021 Hi, I have 2 versions of Machines one uses V570 and the other one v700, FOR THE v700 The SD browser tool from the HMI looks very tiny (I assuming because of the resolution), the same with the info mode menu. Is there a way to adjust that to use all the screen? and also I've noticed that that menu (SD browser) Can not be displayed with the remote operator. Is there a way to fix that or Should I start to build myself a menu for browsing the SD Card files ? And another thing that I noticed is that for whatever reason v560 feels more responsive than V700... clearly, I am not an expert on Unitronics, but isn't V700 supposed to be the better one? Quote Link to comment Share on other sites More sharing options...
