Kieran B Posted October 7, 2021 Report Share Posted October 7, 2021 Hi there Is there anyway to set a maximum time limit to allowing a remote access connection to be open for We are on a 4g connection etc all working normally but 1 of the operators keeps forgetting to close his connection, using up all the data So I was hoping there was a way to do this either in PLC ladder or from the Remote operator app? I am using socket 3 set up to 20256 I have tried a timer running on socket 3 connected, that once timed out forces the socket closed, until socket is no longer connected, I have also forced closed for 30s However once these timers elapse remote operator just reconnects and carries on usually with prompts on screen Quote Link to comment Share on other sites More sharing options...
