Damian Posted August 31, 2011 Report Share Posted August 31, 2011 When I set something to "Transparent", Instead of actually being transparent it assumes the background color of the screen. This is a problem because it is common for us to want to put controls on Frame objects. Therefore we would expect the object on top of a frame that has "tranparency" to show the frame behind it. Instead it blocks it out using the screen background color. Quote Link to comment Share on other sites More sharing options...
