Jerrel Posted August 17, 2022 Report Share Posted August 17, 2022 Good Evening, I've a flow meter which giving outputs of 1x 4-20mA HART (Active). Is it possible to read 4-20mA (HART - Active) signal using Unistream' IO Module UIA-0402N (normal 4-20mA module)? Thanks. Quote Link to comment Share on other sites More sharing options...
Ivgeny Posted August 19, 2022 Report Share Posted August 19, 2022 You can read the 4-20mA , without HART protocol support. For HART support, use UIA-0800NH. Quote Link to comment Share on other sites More sharing options...
