Walkerok Posted September 20, 2011 Report Share Posted September 20, 2011 This is for a V560. I have a customer that is requiring that I not use either the on screen keypad or the number keypad that is on the V560 to change the value of a number setting on screen. While functionally it is easy enough for me to use the touch property of a number box on screen to allow the use of only the up down arrows on the keypad to meet the customers requirement, I am finding the marking view to have little useful information in the help files. I read where I am supposed to be able to change the settings of an item when ever a marking view bit is set, but on the number variable itself I see no way to change what the values are for when the marking view becomes true. I am sure this is easy, but I can't find it. Thank you Keith Link to comment Share on other sites More sharing options...
Walkerok Posted September 21, 2011 Author Report Share Posted September 21, 2011 Ok, Thank you live tech support for the answer. And, as suspected it is very simple. Just double click any open area on a screen and the menue that comes up to change the whole screen background also brings up what default colors will be applied to objects on that particular screen for "disabled, focus, and marking". Make the needed changes on that menu and you are good to go. Keith Link to comment Share on other sites More sharing options...
