Graham Witkowski Posted November 14 Report Share Posted November 14 Hi I have built a winding machine that moves material from one roll to another. Normally with is done to a set length, the machine slows down the rolls and stops at a given point, via input from a shaft encoder. basically the Samba is fancy 2 stage counter linked to a VFD. The user would then typically cut the material, add a new roll, reset the counter and press start again. I have customer who wants to be able to have the machine wind their material roll to roll and stop at 3-4 random points throughout the 50m roll - this is for the purpose of a quality control check their product. without cutting the material at all. I need the slow down and stop to be automatic, I could add a 'resume' button to continue to the next stop point, before finally stopping at 50m. I have uploaded the original working programme. Any assistance would be amazing. Thanks Final Vers 1.3 180823 no over temp 305dc.vlp Quote Link to comment Share on other sites More sharing options...
