mk1d Posted January 15, 2013 Report Share Posted January 15, 2013 I have a program with 4 timers that go in sequence. I want to display all 4 timers' current value on 1 display screen. I've figured out how to display the timers using the SI142 method, but when I test the display all I get are a bunch of goofy numbers. When the timer is set under 1 minute it works great in standard time format but if I set the timer for 10 minutes or more it doesn't display right at all. Can anyone help me out? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 15, 2013 MVP 2023 Report Share Posted January 15, 2013 Post your program. Joe T. Quote Link to comment Share on other sites More sharing options...
