Maulik Posted May 3, 2013 Report Share Posted May 3, 2013 I have installed visilogic 9.5. When i open the software, i m getting error 9 permission denied. pls help. rgds, maulik Quote Link to comment Share on other sites More sharing options...
Alexander Posted May 3, 2013 Report Share Posted May 3, 2013 If this was an upgrade from a previous version some files may not have been erased on the reinstall. I have included the link for reinstall instructions if you are using a Windows 7 or Windows Vista OS. It may be necessary to reinstall VisiLogic if it was installed with UAC still enabled. For other operating systems it is the same reinstall process with the exception of disabling UAC. After reinstall it is also suggested to run the program as an administrator. http://forum.unitronics.com/index.php?/topic/664-can-i-use-visilogic-with-vistawin7-uac/ Quote Link to comment Share on other sites More sharing options...
Maulik Posted May 6, 2013 Author Report Share Posted May 6, 2013 thanks. problem solved, rgds, maulik Quote Link to comment Share on other sites More sharing options...
Tryggvi Posted March 4, 2014 Report Share Posted March 4, 2014 I got this same problem popping up when I was installing 9.6.0. I also tried 9.5.0 with the same results. I tried uninstalling and delete all files several times with diffrent versions of the software before I came accross this guide. And now this finally works, thank you very much. Quote Link to comment Share on other sites More sharing options...
