AnibalBen Posted October 25, 2014 Report Share Posted October 25, 2014 Hi I need help with visilogic, I have installed several times and always ends in a critical error by reinstalling it can not open the last job that I did, and this can cause me a big problem in my work. probe operating systems are windows 7-64 bit and xp 32 bit. I do not imagine anything more to be done. I leave some pictures below of what happened. thank you very much Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted October 29, 2014 Report Share Posted October 29, 2014 Hi Ben, Please try the following: 1. Follow the instructions described in the following link: http://www.unitronics.com/docs/pdf/disable-uac-vista-win7.pdf?sfvrsn=2 2. Download the installation file again from here: http://www.unitronics.com/downloads/support/visilogic/VisiLogicSetup_9_7_Build24.exe 3. Before executing the installation file, make sure it is unblocked by right clicking the file icon-->select Properties-->press on the Unblock button. 4. Run the installation file as administrator. Quote Link to comment Share on other sites More sharing options...
