Blitz Posted January 8, 2011 Report Share Posted January 8, 2011 Mounting horizontally an adapter and eight expansion I/O modules would not fit in our cabinet. So, one option is to mount the modules vertically. I just like to confirm if vertically mounting the modules is allowed and without any effect on the rated specifications and normal operation. - e.g., since the vent holes would be on the sides when modules are mounted vertically, does the operating temperature gets de-rated from the max. of 50 DegC? - e.g., any effect on operation of relay modules? - would it matter whether the adapter module would be on the top side or bottom side of the column--e.g., effect on heat dissipation? Thanks. Quote Link to comment Share on other sites More sharing options...
Emil Posted January 11, 2011 Report Share Posted January 11, 2011 Hi, Locatging vertically expansion modules is very often applied soluiton. currently no problems with it. Quote Link to comment Share on other sites More sharing options...
