jur89 Posted July 21, 2017 Report Share Posted July 21, 2017 Hello Can anybody help me with the problem i am having. I have 2 almost identical net-s, one working the other not. They both set O80 on for the duration of the timer. Net 3 works, but net 2 will not set the output ON. The rest of the net is working. After the timer expires the bit resets like it should. Only problem is the O80. I tried changing it with something else (other output, a MB), but it still wont turn on. I know i must be overlooking something extremely simple, but i cant find it. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 21, 2017 MVP 2023 Report Share Posted July 21, 2017 You cannot have the same Direct Coil in two different ladder rungs. Only the second instance of the coil will control the output. 1 Quote Link to comment Share on other sites More sharing options...
jur89 Posted July 21, 2017 Author Report Share Posted July 21, 2017 Well i knew it was something simple Thank you Quote Link to comment Share on other sites More sharing options...
