Maulik
Run Time Error 2147024770 (8007007e) Automation Error
Hello....
I have freshly installed  latest version of Visilogic on Windows 7 Professional , 32 bit os. I cannot use visilogic because I get following error :-
"Run Time Error 2147024770 (8007007e) Automation Error"..
Please help...
Rgds,
Maulik
Did you install VisiLogic "As Administrator"?
Do you run VisiLogic "As Administrator"?
Does it do this when you open other projects, or only this one?
Is this a new problem (i.e. was VisiLogic running fine and then suddenly developed this problem)?
Which version of VisiLogic?
