Hello !
I have to use a PT100 sensor with a V350 PLC.
I can't understand how to connect the sensor to the PLC because it shows MI = 32767 once connected.
Sensor Reference: RS 896-8406
Thank you  and have a good evening.
Guillaume.
The Installation Guide document I pointed you to tells you everything you need to know. It says how to set the jumpers, where the jumpers are and how to access them. Jumper setting is on page 5 and how to access them is on page 10.
