VNC connection between "Unistream PLC to PC"
This is not a Unitronics issue or problem - it's a networking issue. There are many ways to do this, but there are complex security issues involved. You need a networking professional to handle it or advise you. The simple (and least secure) method is to set up port forwarding with the router that the PLC is connected to if that router has access to the internet with a static IP address assigned.
