wapcs Posted July 5, 2018 Report Share Posted July 5, 2018 I've set up a Web Server page to display Timer values (Elapsed) but the box remains blank. Labelled in the attached image as 'Match Time' and 'Game Time' Any advice on what the issue might be would be appreciated. Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 5, 2018 Report Share Posted July 5, 2018 Are all the other tags show the correct values? Can you upload the project, so I'll try reprooducing it here? 10x Quote Link to comment Share on other sites More sharing options...
wapcs Posted July 5, 2018 Author Report Share Posted July 5, 2018 File attached Thanks TTWA.ulpr Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 5, 2018 Report Share Posted July 5, 2018 The good new are that I'm able to reproduce it with your project. I'll have an answer next week, since I need to understand why in my small example it worked, while in yours it doesn't. Quote Link to comment Share on other sites More sharing options...
wapcs Posted July 5, 2018 Author Report Share Posted July 5, 2018 Thanks. I look forward to your reply Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 5, 2018 Report Share Posted July 5, 2018 I think that it worked on my example because I had in my web page both Present, Current and Elapsed, so this is kind of a workaround. You can put 2 more Timer Boxes for each timer, with the Present and the Current, and link the Visibility Bit to the System tag General.OFF Please tell me if it works. After I'll fix this issue, the fix will be scheduled to a version that will be released in 2-3 months. (So it is good if the workaround works) Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 8, 2018 Report Share Posted July 8, 2018 Yep, In timer Elapsed it should link to both Present and Current, but due to a small bug, it links to the Out member, so the workaround is what I've suggested above (Until the fix will be released in few months). Quote Link to comment Share on other sites More sharing options...
wapcs Posted July 12, 2018 Author Report Share Posted July 12, 2018 Thanks Saragani. I'll keep an eye on the updates. Quote Link to comment Share on other sites More sharing options...
