plcnewb Posted July 27, 2018 Report Share Posted July 27, 2018 I'm using VisiLogic 9.8.65. I'd like to include revision change notes inside ladder logic comments and then be able to search for these changes. However, I can't find a way to actually search the comments in the project. The find options include elements, operands, function blocks, etc., but I don't see a way to find items in the comments. Is there a way to find text in the comments? Quote Link to comment Share on other sites More sharing options...
jaycklein03 Posted July 30, 2018 Report Share Posted July 30, 2018 Hello, This probably isn't as elegant of a solution as you are looking for, but you can turn your ladder code into a PDF and search for text in the comments that way. Just go to print and save as a pdf, then hit cntrl - F and type what you want to find in the search. You could also just make a bit that does nothing and give it a name you can search for later. Like I said, not elegant but I can't think of another way in Visilogic. Best of luck to you. 1 Quote Link to comment Share on other sites More sharing options...
plcnewb Posted August 1, 2018 Author Report Share Posted August 1, 2018 Thanks @jaycklein03! I hadn't thought of that. I agree that it is a little cumbersone, but that is better than what I have now. For big projects I can see that being better than visually searching through the code. Quote Link to comment Share on other sites More sharing options...
