JotaPey Posted November 13, 2018 Report Share Posted November 13, 2018 Upon analyzing my project, several error messages were produced concerning fixed text on my HMI module screens. The error description is "missing tag action 0". I assume this is talking about the "Tag: Touch Enable" under attributes in Properties Window. If I mouse over that element it tells me the Touch property is enabled by default. How do I disable this, so that the text is not touch enabled? I looked in a sample project and the attributes of a fixed test element were the same as mine (enabled). Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted November 13, 2018 Report Share Posted November 13, 2018 Dear JotaPey, one of the attributes is called "actions", first in the attributes list, if you select this a small window will appear...in this window you can select many actions (set or reset BIT, load screen etc)...maybe you have added one action but without coupling the specific BIT to set or other...please check. 1 Quote Link to comment Share on other sites More sharing options...
JotaPey Posted November 14, 2018 Author Report Share Posted November 14, 2018 Thanks ORSO2001! That was exactly what I was looking for. It looks like it added an action that was empty by default. I appreciate your help. Quote Link to comment Share on other sites More sharing options...
