JotaPey
Clear Struct with Reset Numeric
I would like to clear all the data in a certain struct.  I thought I was able to do that using the Reset Numeric function.  I entered the name of the struct in the function box tag and then erased the period.  For some reason, however, the data is not being cleared in the struct.  Am I wrong in how I set this up, or am I overlooking something?
I tested it with a struct, and it works.
Can you try to "Build-All" and then download the project to the PLC? (It should say that the project is identical, if you have not changed any thing).
If the project was downloaded (meaning, no identical project message), then check if the Reset Numeric now works correctly.
  • Upvote 1
Thanks for the reply Saragani, can you explain to me what "Build-All" does?  On my version it has "Rebuild-All", which I assume does the same thing.
Register a new account
Sign in
