jvalstar
Data tables shuffled
I'm having a problem with the data tables in a UniStream PLC. Sometimes one column of the data table had been shuffled randomly.
Does anyone know about this problem? The data table is retained and battery is OK.
Hi jvalstar,
I never had this problem...what I can suggest to check is, if the shuffled column is always the same, where this column is "used"...maybe you are copying an array in this column and you haven't the full control of this action...I mean that maybe you haven't managed all the possible causes that can enable this action...
if you want share your project and highlight which column has this "problem" maybe someone can will take a look.
regards
