Did you look at the Help file? The example is for an older PLC, but the basics are the same. When you place the Timer HMI element on the screen, link to the timer operand you want, check the Preset box, and the Keypad Entry box. Also, set up the Format and other niceties for your HMI element. That's all there is.
  • Like 1
 Yes problem solved, just needed a guideline such as yours. Thank you....
I'm having another Timer problem to program a coil that we be energized  for a specific period of time but I will just start a topic for it. Thanks once again
Use a TE Timer and activate it with a positive transition.
  • Like 1
