Sign in to follow this
Hello !
So I'd like to connect an Siemens API to my V570. I know that I can use a gateway tanks to an other API (V130) and a port profibus. But I have other Siemens APi i'd like to connect, is it possible to add more port profibus on my V130 ?
Thanks
Jessica
Hi Alex :
By that I meant that I had more than one Siemens API (4 actually) and I'd like to connect all of them to my V570 via Profibus.
26 minutes ago, AlexUT said:
Only one ProfiBUS card allowed.
So the only way to have communication with all of those API is to use a Vision API with profibus communication for each of my Siemens API ? Is there an other option (still with Profibus)  ?
You can read required MI from V57 PLC by V350, and read both values from V130.
So you mean that I can't connect the V130 to the V570 ?
Jessica
