RestcDavies Posted December 10, 2019 Report Share Posted December 10, 2019 Can Ping device on 192.168.1.1 but cannot uploadV350-35-TR20 Quote Link to comment Share on other sites More sharing options...
DanT Posted December 10, 2019 Report Share Posted December 10, 2019 (edited) Posted Thursday at 11:19 AM COPIED HERE AND EXPANDED Hi; Having Issues trying to communicate with the PLC via Ethernet ? Some Guidelines : Is the Ethernet Cable Plugged into the Ethernet Port ? and are the LED's Flashing for connectivity? The Expansion port uses a RJ45 Connector also, and is often confused with the Ethernet port. Are the PLC and the PC on the SAME IP Base Address Structure ( network)? e.g. 192.168.1.x If the connection is direct, consider a Crossover Ethernet Cable. Can you PING the PLC IP Address from the PC and get a reply? Check the PLC using INFO Mode ( Password 1111) Ethernet Upper lines show Ethernet IP and current status Middle allows you to view and set parameters - IP, Sockets Press Monitor to see if any data is reaching the PLC ( selectable by the port ) Check the PLC NAME ( This is the PLC's Password - needed for Ethernet Downloads ) Name is under Version - Software - On New Units -- it is a number ( This can be changed in your VisiLogic Program) In VisiLogic : ---| | -----=------PLC Name -- Set the IP ---Set up Sockets SB2 SB2 is a Power up one shot that runs only 1 time in the program - at Power UP - used to set parameters Always set up the Ethernet Settings within the first few Nets in the MAIN Program ( NOT in a subroutine !) ( Same for Serial Ports ) There are default settings for sockets, but they can be changed to what you want them to do. Check Help for the default sockets When attempting to download the first time using the Ethernet Port setting up an Ethernet Connection the first time, there are 2 options 1 Check the PLC Name in Info Mode and the IP Parameters. Under communications and setting, set the Ethernet Parameters using the NAME from the PLC ( After the program is downloaded, the name can be changed to your PLC Name ) 2 download the program thru the serial port or USB Port -- this way the PLC Name is Set YOUR way Edited December 11, 2019 by DanT Added Details Quote Link to comment Share on other sites More sharing options...
