I'm doing a datalogger with a PLC Vision 130. This has to perform the following tasks: 1- Survey by Modbus to slaves 2- Save every 1 second the intoaccount to a table 3- Once the table is filled, pass the data to SD A full time card as I do to delete the first record of it to generate a cyclic deleted ??.
Have a look at this post and it might give you ideas.  Not exactly what you want, but near enough.
Keep in mind that if you are communicating with a few slaves by modbus, you may not be able to do an accurate save every second, due to the inherent delays in the comms.
cheers, Aus
Sign in to follow this
