Dezweb52 Posted October 10, 2011 Report Share Posted October 10, 2011 Hi, I have been having difficulty with this one for a while. I have managed to get the advanced web server up and running on my Vision 130 and I am able to access the home page that I have set up (Start.htm) that is stored on the SD card. However, when I try to access any other pages it always seems to load up the Start.htm page, not the page I'm trying to access. I have even tried going to /web/ but with no luck. Am I missing a configuration? I'm unclear why I can't seem to load any other page other than the Start.htm. Many thanks in advance! Quote Link to comment Share on other sites More sharing options...
Hladil L. Posted October 20, 2011 Report Share Posted October 20, 2011 Hi, I have been having difficulty with this one for a while. I have managed to get the advanced web server up and running on my Vision 130 and I am able to access the home page that I have set up (Start.htm) that is stored on the SD card. However, when I try to access any other pages it always seems to load up the Start.htm page, not the page I'm trying to access. I have even tried going to /web/ but with no luck. Am I missing a configuration? I'm unclear why I can't seem to load any other page other than the Start.htm. Many thanks in advance! I had the same problem. think that you may have set the link HTML code wrong. Make link to new page on your Start.htm page - for example page Start2.htm and load it in Web directory of SD card, HTML code for link should contain something like <a href="/Web/Start2.htm"> Then try to click on this link - it should work. Look in web server help on HTML code examples on pages 9 and 10. Quote Link to comment Share on other sites More sharing options...
