pascal Posted February 19 Report Share Posted February 19 Hi, I want to communicate with a IoT trough MQTT. I managed to send simple JSON commands, but i'm looking how to configure more difficult JSON structs... I want to send this telegram to my IoT device, but I don't have any idea how to setup my json struct.... has to look like this..... { "FountainSchema": { "enable_pump_1": true, "startclock_pump_1": "08:30:00", "stopclock_pump_1": "14:00:00", "enable_remote_frequency": false, "remote_frequency": 32.8 } } I know I can make a struct like this : enable_pump_1 = BIT startclock_pump_1 = ascii[8] stopclock_pump_1 = ascii[8] enable_remote_frequency = BIT remùote_frequency= BIT but how do I get the tag FountainSchema into my json struct ? like I want to receive some publications made from my IoT device : { "metrics" : [ { "name" : "response", "tags" : { "organization_id" : 1, "company_id" : 1, "tasktype_id" : 91, "service_id" : 77, "project_id" : 501, "task_id" : 1659, "property_id" : 111, "propertytype_id" : 999 }, "fields" : { "measurement" : "switch_pump_1", "value" : 5, "type" : "switch" }, "timestamp" : "2024-02-14T14:45:16.000Z" } ] } how and where do I program my JSON struct I want to publish or to subscribe ? Quote Link to comment Share on other sites More sharing options...
Ivgeny Posted February 20 Report Share Posted February 20 Hi, There's no yet support for a nested STRUCT over JSON, if the structure is not too complex, you can try maybe (never tried) to build an ASCII buffer having the entire JSON and publish as a RAW type. Need to try that. Message composer feature might make your life easier, building the structure once and setting the values of the tags to get the buffer that will have the exact JSON structure.. Quote Link to comment Share on other sites More sharing options...
pascal Posted February 21 Author Report Share Posted February 21 Hi Ivgeny, Thanks for your reply. Indeed, I think I have, like you said, to use the message composer for publishing nested structs in JSON and send them as raw data. I only have 1 question about the message composer -> you can scan a message, but what with receiving a variable as ascii, but the length of the ascii can be different... the ascii variable in JSON is always between "", but I don't see how to program this. I thought the ascii variable has a fixed length in message composer ? Quote Link to comment Share on other sites More sharing options...
