HansCZ Posted February 25 Report Share Posted February 25 Hello, I am trying to build a wide remote control for my unitronics (especially Unistream) projects. The solution is based on Teltonica routers and Wireguard. Everything works more or less fine but the only issue is when I am using noVNC web client, the mouse cursor disappears. You can kindly test it here https://plc.ipraqua.cz:6080/vnc.html?autoconnect=true&path=?token=test I know there was the same issue on old versions of UniCloud and further found it is a problem on server side (thus in this case on the PLC). Does anybody know any solution? PS: I am not using unicloud as this solution is too expensive and not so functional (like on one application I have a combination of Vision V350 and Unistream B7 and using wireguard I can connect even to Vision and even modify user program) Thx Jan Link to comment Share on other sites More sharing options...
HansCZ Posted February 29 Author Report Share Posted February 29 I am a fool. There is a checkbox "With Cursor" in the PLC - VNC server. It is not in the UniLogic VNC options, so was a little bit confused, but works. Link to comment Share on other sites More sharing options...
