Hoops123 Posted March 4 Report Share Posted March 4 Hello Members, I'm working with PLC USC- B5-T42 and HMI USL-050-B05. I have created an enegry saving mode that switches certain things off when the machine has been idle for over 30 minutes. In order to wake the machine back up again I though i would use the "touch bit" . The touch bit however doesnt work, I can press all over the HMI and the bit doesnt change state. Is it the case that the touch bit only works for the built in HMI and not via VNC? Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted March 4 Report Share Posted March 4 Here the solution. 1 Quote Link to comment Share on other sites More sharing options...
