dan_lorentz Posted November 23, 2011 Report Share Posted November 23, 2011 So I have a program that is using the SMS communication functionality and I am actually using multiple SMS Configuration blocks depending on what the setting in the PLC are and everything was working fine until I started playing with the SMS Send function block. I now can't download my code and even though it tells me to delete the net and re-enter it, and that doesn't work. Attached is the error message. Are there any limitations to the SMS send blocks? Can only one block be in a net? Has any one had this issue before? Thanks, Dan Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted November 23, 2011 MVP 2014 Report Share Posted November 23, 2011 I would definitely follow the advice of the dialog box and email the problem file to support, as the first step. While you are waiting for a response you can try deleting the net, then do a "build all" and downloading. Then try adding the net back in and do "build all" again. Do you have a recent copy of the program from before the problem? Did Visilogic crash while you had the SMS send block open for editing? Link to comment Share on other sites More sharing options...
luiscostaest Posted June 29, 2015 Report Share Posted June 29, 2015 Hello, I have a problem when programming something that allows me to automatically resend a message that has not been sent successfully. If just one SMS Send is used the SB185 Fail SMS and there is no problem. But in my case, I have three Send SMS that can send at the same time and using the SB185 will only send the last two sms. please help. Link to comment Share on other sites More sharing options...
