julle Posted December 4, 2011 Report Share Posted December 4, 2011 Hi. As just beginner I 'd like to get program example how to manage pump control which uses my fine working (4-20 mA) linearization block. Assuming next step would be compare it to certain values which should be able to change by up/down arrows.. So I could keep vessel level between adjustable minimum / maximum by the pump. Any links to examples? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 4, 2011 Report Share Posted December 4, 2011 Hi julle, I recommend you start from Examples of Visilogic. Shortest way to open Examples is to go to "Help->Examples...) menu option. Then go to "Version 900->Project examples" directory. "V280_ON_off_control_with_hysteresis_and_high_and_low_alarms.vlp" project was written for heating control with hysteresis. This project will be adopted to control Pump. "V120_Variable_enter_control.vlp" project is a simple example fo Variable entry control. I hope this answers your questions. Quote Link to comment Share on other sites More sharing options...
julle Posted December 5, 2011 Author Report Share Posted December 5, 2011 Ok. Thanks for quick answer Alex, I do as you told. Nice to have this support Quote Link to comment Share on other sites More sharing options...
