bender Posted December 7, 2011 Report Share Posted December 7, 2011 Hello all I manage a recipe as a 30 MI vector (temporary buffered on PLCs main memory), and need to back it up on SD card. I must be able to: 1. Write what is stored in the PLC buffer to SD using an index. 2. Restore an indexed 30 MIs block from SD card to the buffer in PLC main memory. Some time ago, I worked the same way but with Data Tables. The problem is I need a lot of memory to store a lot of recipes, so want to use SD. Perhaps if I can use some function like "DataTables Write Row" or "...Read Row", but directly on the SD. I don´t know how to do this the best way, if possible. I´m working with V130. Thank you. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 8, 2011 Report Share Posted December 8, 2011 Hi bender, I recommend you to start from Data Tables Webinar: http://www.unitronics.com/Content.aspx?page=datatables Please note, you can exchange data between SD card and Data Table at OPLC: -Use Data Table functions; -Use SD Data Table functions; -Note that the main DT folder and subfolders DT1, DT2, DT3, DT4 can each contain 64 files, for a total of 320 .udt files. This way you can handle up to 320 files on SD card. You can then read information from SD files to OPLC memory. You can use also SD function Block Read/Write , but it seems a little more complicated. Answer may be more specific if you provide more information about your project requirements. Quote Link to comment Share on other sites More sharing options...
