PCSControls Posted December 16, 2011 Report Share Posted December 16, 2011 I have a V570 with a V200-18-E3XB snap in card. I have a simple numeric on the screen that displays the temperature of the t/c connected to ain0 and this works OK. When I add a TREND graphic and download to the V570 the numeric displays "0.1" and the trend does not display proper data either, If I delete the trend the numeric updates properly with the expected temperature values. Any Ideas ? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted December 20, 2011 Report Share Posted December 20, 2011 Hi, Please check if you use in a Ladder the same MI for Trend and TC. Check power connection to snap in card. There is no idea without knowing what exactly you are doing. Quote Link to comment Share on other sites More sharing options...
