JohnnyB Posted January 11, 2012 Report Share Posted January 11, 2012 Guys When i make a download that my project on PLC V130-33-T38, after the download finish the hmi show a message : " hold (i) for info mode. © Unitronics No app. After this, if i make a new download that same project - the program run perfectly. I try download the same program on two PLC 130 and occurred the same thing. If i download a blank projet, the program run fine and this problem don´t happen. I make tests change the values bauld rate (for serial connection) and download through ethernet. How is possible fix it ? In time, i use the Visilogic 9.3.1 Build 0, Windows 7. PLC ´s using firmware 03.004.25 (27/11/2011). Link to comment Share on other sites More sharing options...
