Convert ASCII to Float, MI to MF
I need to convert an ASCII string value into a Float and / or need to convert an MI value into a MF variable. I've looked but don't see a simple way to do this.
Am I missing something?
Thanks in advance!
Hi
The function ASCII TO NUM can be found in the String menu, in the Help menu use this path to find how to use the function: Home>Ladder>String Functions>Strings: Num to ASCII, ASCII to Num
To convert MI to MF use the function A+B/n, it can be found in: Math>Float>Convert
Emil
