YINGD Posted March 2, 2012 Report Share Posted March 2, 2012 I am using a remote IO-AI4AO2 for an application. Does anyone know if it is possible to change the Input and/or Output type from Voltage (0-10V) to Current (0-20mA) via the HMI screen rather than having to change it through the Hardware Configuration in VisiLogic? Quote Link to comment Share on other sites More sharing options...
Damian Posted March 12, 2012 Report Share Posted March 12, 2012 This tire has already been kicked a few times. http://forum.unitron...ch__1#entry2997 That was related to T/Cs, but really it is the same question. Some things require jumpers, but even so, the ability to select in software still allows the operator to make the jumper change only without fussing with the program. Quote Link to comment Share on other sites More sharing options...
