drewh Posted May 22, 2012 Report Share Posted May 22, 2012 Why was this done? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 24, 2012 Report Share Posted May 24, 2012 It is done this way because a PLC object is an object that already has an active connection and that already established a conversation with the PLC. What do you need from the PLC object? (Why to you need to subclass it)? Maybe there is an easier solution for what you are trying to do. Maybe the thing that you want to implement can be added as a feature to the communication driver (if it's usefull). Quote Link to comment Share on other sites More sharing options...
