gmkispal Posted June 5, 2012 Report Share Posted June 5, 2012 Hello, Have I posibility to take out the project from Jazz PLC and import it in PC to analize how it was the ladder created if the project wasn't protected with password? Thank You and sorry for my bad english. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted June 6, 2012 MVP 2014 Report Share Posted June 6, 2012 The U90 Ladder software is able to copy the program from the Jazz back to the PC to view and edit the ladder. Use the "upload" option from the "controller" menu. You will need a JZ-PRG communications adaptor if one is not already fitted into the PLC. As you have mentioned, if the program is password protected, you will need to enter the password to upload. It is also possible to disable the project upload feature when the project is downloaded to the PLC. If this was done, then it is not possible to upload the project at all, and the software will give an error message. Quote Link to comment Share on other sites More sharing options...
gmkispal Posted June 6, 2012 Author Report Share Posted June 6, 2012 Thank You the answer! Quote Link to comment Share on other sites More sharing options...
