esoula Posted June 21, 2012 Report Share Posted June 21, 2012 Hi, Would anyone know if it's possible to access the sdcard's files directly from TCP using either the COM Object ActiveX.dll or the Net Driver. In fact I don't want to use the SD Card Suite tool... Regards Manu Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 22, 2012 Report Share Posted June 22, 2012 The SD Card Suite has a tool called SD Card Explorer which uses the .Net Driver for accessing the SD Card. Quote Link to comment Share on other sites More sharing options...
esoula Posted June 23, 2012 Author Report Share Posted June 23, 2012 Thanks. But i was looking for developping my own VB tool in order to access the SDCard from a TCP connection with the PLC... anyone has done similar tool previously? Manu Quote Link to comment Share on other sites More sharing options...
Saragani Posted June 23, 2012 Report Share Posted June 23, 2012 "...SD Card Explorer which uses the .Net Driver for accessing the SD Card." Look for the plc.SD class for functions of reading and writing files. Please contact our support for more information. Quote Link to comment Share on other sites More sharing options...
