JohnnyB Posted June 23, 2012 Report Share Posted June 23, 2012 Hi Guys. About digital output, is possible i connect other power source (24vdc) to output, or is necessary i connect the same power source that Input (PLC) (same circuit). Thanks for all Quote Link to comment Share on other sites More sharing options...
dahnuguy Posted June 28, 2012 Report Share Posted June 28, 2012 no You want a relay out if you want to send your own signal through the output. Or you could hack the PLC and pull the supply side on the transistor out and put your signal in. While your in there, might as well change the transistor to a FET , might need to add a resistor so the gate gets the right voltage. Should be fun. Quote Link to comment Share on other sites More sharing options...
