sokrates Posted July 10, 2012 Report Share Posted July 10, 2012 Jazz is a problem with the countdown in the PLC model. Namely, the set value can be seen in the accompanying drawings: 23:59 'set up. Grekeli contact input arrival whether to start counting down began. I watched the beginning, wait. Remaining: 23:13 '23:12 after ten, but was 23:73. In an odd situation. Added a full 60 minutes. Then started counting upwards. After a while, began to count down again. "ANY" can also add hours and minutes, seconds him? (HH: MM: SS) enigmav3.U90 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 11, 2012 Report Share Posted July 11, 2012 Hi, Please create an empty program, which include only timer which have a problem and test it. If in this short program problem arise again - send your project as is to support@unitronics.com. *You do not need to make photos, you will make a screen capture in online mode of U90Ladder from computer. If problem disappear - you need to review your program for errors in code. In this case your Local Distributor will assist you. Following link is an International Distributors list: http://www.unitronics.com/Content.aspx?Page=Distributors BR. Quote Link to comment Share on other sites More sharing options...
