RShanty Posted July 16, 2012 Report Share Posted July 16, 2012 I use the Set function to set bits. Is there a way to clear (reset) all the set bits without haveing to use individual Reset Bits? Thanks Quote Link to comment Share on other sites More sharing options...
Emil Posted July 16, 2012 Report Share Posted July 16, 2012 You can use Vector Fill function to reset (Fill with SB0) a range of bits. Is this OK? Quote Link to comment Share on other sites More sharing options...
RShanty Posted July 16, 2012 Author Report Share Posted July 16, 2012 Yes that worked. Thanks for the quick reply> Quote Link to comment Share on other sites More sharing options...
