dahnuguy Posted August 6, 2012 Report Share Posted August 6, 2012 I am aware that I can export and import a subroutine. In previous versions of VL, I was also able to build a generic subroutine and then , without leaving the editor, highlight the subroutine, press cntrl+c and then highlight the module and press cntrl+v. A new subroutine would appear with the same name as the copied subroutine with a "_01" after it. ( or something similar) original_subroutine original_subroutine_01 original_subroutine_02 etc Then I could use the replace function to change the memory in the new subroutine. Since my mouse has 2 buttons mapped to copy and paste this was a two click operation. And it was very quick and useful. I noticed that there was no copy paste in the right click menu when a subroutine is highlighted, but the keyboard keys still worked. Was this changed intentionally for the new version? Is there a way to add this back in? Quote Link to comment Share on other sites More sharing options...
AlexUT Posted August 7, 2012 Report Share Posted August 7, 2012 Hi, Please send your request about interface changing to support@unitronics.com Add details about previous version of VL where you used it and other details. BR. Quote Link to comment Share on other sites More sharing options...
