gregory Posted August 13, 2012 Report Share Posted August 13, 2012 DEAR SIRS DOES ANYONE HAVE SOME SAMPLE PROGRAME TO CONECT MORE THAN ONE UNICAN EX RC1 MODULES IN UNICAN NET. I USUALLY USE ONLY ONE EX RC1 + IO EXPANSION MODULES IN PROJECTS. I HAVE MUCH TRUBLES TO CONECT SECOND EXRC1 MODULE. FOR A ONE MODULE I NEVER HAVE DIFICULTIES FOR 1 EX-RC1 UNIT THAT SOFTWEAR HAS BEEN CONFIGURATED FROM UNITRONIC UNICAN SAMPLE AND WORK SUPER. FOR A SECOND EXPANSION A HAVE MUCH DIFICULTIES , DIP SWITCES HAS BENN CONTOLLED WIRES ARE OK BUT BUS COMM FLASSHES ALL THE TIME. USE MI 2024 SOFTWEARE TRIED COUPLE TIMES AND NO SUCSESS. PS. PLC VISON 1040 .......ID1 UNICAN ....... ID2 MODULE1 EXRC1 CANOPEN ..... ID3 YAKSAWA V1000 FREQ CONV. UNICAN2 ....... ID4 MODULE1 EXRC1 DOES ANYONE HAVE ANY SUGGGESTION. KIND REGARDS GREGOR . EX-RC1-SKUPNI ID1.vlp EX-RC1-SKUPNI2 ID4.vlp Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted August 14, 2012 Report Share Posted August 14, 2012 In ID=4, why do you use #4 as destination in UniCAN Send, Arrived and check alive FB´s? As I understand, it should be #1 to proper communicate with master PLC Quote Link to comment Share on other sites More sharing options...
gregory Posted August 15, 2012 Author Report Share Posted August 15, 2012 THANKS GABRILE FOR HALP............ YES I REALISED THE ERROR . I ASK FOR HELP ALSO GUYS FROM UNITRONICS AND THEY GAVE ME SUPER SAMPLE PROGRAM I WILL ATTACKED IN FILE. GREGOR EX-RC1 ID2 AND ID3.vlp Quote Link to comment Share on other sites More sharing options...
ftroche Posted February 25, 2015 Report Share Posted February 25, 2015 Good morning, my problem is this, I have a V1210 panel and two modules EX RC1, in the first eight ATC8, in the second three ATC8 and one IOD16TO16. By placing the hardware first and placed 8 ATC naming the variable by 5 tells me that the capacity is exceeded. The truth is not good to do but I can not solve. Quote Link to comment Share on other sites More sharing options...
