Fre_ZZe Posted September 19, 2012 Report Share Posted September 19, 2012 Hi, I'm having trouble downloading my application to a new and clean V350-35-R34, it fails over both serial and ethernet. Loading Bin. Lib, Boot, OS and Sync RTC works fine. My UDC file contains the following, and I'm trying to execute using UniDownloader v. 4.1.02: Bin.Lib v. 2.1 (02) BOOT v. 2.1 (06) OS v. 3.0 (67) Sync. RTC Application As said, I'm able to download Bin.Lib, Boot and OS. I then do Sync RTC fine, but when trying to only execute the application item to the PLC it says Application failed. This happens during: Status: Downloading String Lib to PLC. The UDC file is 628kb big. This is creating big problems for me at the moment, as I need to be able to distribute this UDC with the new application to a lot of customers..on both old and new PLC's (upgrade/reinstall of application) Any ideas? Quote Link to comment Share on other sites More sharing options...
